Hi all I've got a 07 grande panto 1.4 who's a bit poorly! I've had her from new and this morning my power steering failed pulled over stopped the car ignition off then back on again and it came back on again. I got home and did a bit of research and read it could be a power issue or my colum is on on its way out so I cleaned up my battery terminals cos they were a bit mucky checked for loose connections then started the car again an I've noticed it now makes a little screech for about 2 seconds on start up and it's not a belt or starting motor kind of screech either does this mean the chances are its the column it's self on the way out
