General Power Cable For Amp
Banbury, Oxfordshire
Where can i feed a power cable from engine bay to the cabin? cheers
somewhere by the accelerator pedal, the carpet may need moving out the way.
if u still cant find it, have a look under the battery, its somewhere around there.
i assume it would be the same on a cinq cause i got a sei
Seicento Sporting, Modified Front Bumper, Saxo Custom Spoiler, Abarth Side Skirts, Bad Boy Bonnet, Afterburner Rear Lenses, 4" Powerflow Exhaust System, Abarth 14" Alloys.
IN THE PIPELINE:
-40mm Drop or Coilovers, New Front Bumper, Rear Splitter, New Mirrors (Not the cup ones[xx(], something different)
Check out my site http://badboygaz.mysite.freeserve.com​
FIATForum stickers available PM me for details or see: https://www.fiatforum.com/forum/topic.asp?TOPIC_ID=10000
feed the cable from the battery remover the heat carpet that is behind the battery and you will see a cable that feeds into the back of the dash. this is the speedo cable. take the rubber seal fron the metal and feed the power cable through there then replace the rubber thing. this will bring the cable out behind the speedo clock set and then its a case of feeding it to the back of the car and hiding it. :):) BOC BOC
Little Red Devil (L.R.D). Huge ice on its way. Not too far off 1242cc conversion. Still need a rear bumper. "its proper bo i tell thee!"
