ChrisF
- Joined
- Mar 25, 2005
- Messages
- 284
- Points
- 57
I've posted here a few times about
a) wobbly idle
b) juddering when pulling off in first gear
c) stuttery low speed crawling, particulary in traffic
SO, a few weeks back the car (54 plate 1.6 active sport) went in for it's 2nd Year service, it's only just broke 12k miles. I mentioned the problems above. So they checked out the coil packs, engine idle etc and everything checked out fine. They said it was a clutch fault and replaced it on warranty...fine ok. Didn't quite fix the problem and the gear box felt very stiff. SO i put it down to it being new and it might need some time to bed in.
2 weeks later, on the M77 coming towards a big roundabout, NO GEARS, GRIND GRIND, 1st and 2nd gear unusable, violent judders when pulling away, ...Luckily, I managed to get it home and to the dealers this morning.
Dealers checked it out, got back to me...TADA finally, i think they might have found the problem to all of the above.
The flywheel is "mis-shaped" and has basically been like that for a "long time" hence the reason the clutch had to be replaced the first time. They didn't spot it the first time round. They are going to replace the clutch and the flywheel on warranty and then look into the wobble and see if it is still there.
If this sorts out the problem I'll let you know, hey who knows maybe arnold clark fiat moving away from the alison st branch could be a really good thing...if anything it's now just across the road form my work LOL!:slayer:
a) wobbly idle
