Technical Poor radio reception. Aerial antenna base replacement?
Thank you Koalar. I misread it.
I was actually looking to get the whole piece replaced. There’s only one connector on but the ones online I’ve found are female connectors not male. I’ll keep looking
No problem
There's still two types
With built in amplifier or without
Is there a electronic PCB under the gasket or not
The work differently and are different prices
No problem
No PCB just a single wire
This one shows a male connector
I’m so grateful. Thanks you. I’ll order it.
Thanks again
I pulled back the head lining enough to find the aerial connector plug. A piece of wire (could have been coathanger or something slightly smaller) pushed in to the centre of the coaxial plug going to the radio gave a good radio reception and was a useful temporary fix while I looked for a replacement antenna.
Hi, can you confirm the one you ordered on the eBay link did indeed have a male connector ? I’m having the same issues and had already ordered one but it came with a female plug.
Hi, It hasn't arrived yet. I will let you know when it does
People following this thread, be careful
There is at least 4 different Arial bases
1 lead passive, no electronics the one above
1 lead active
2 leads
3 leads
I don't know which were fitted to which model
I thought the passive was just on the 1.1 active, the fact is now been found on a dynamic, means my original guess was incorrect, the simplest way is to look at your old one first before ordering
