Mr FIAT - Your #1 source for vintage car parts
The FIAT Forum
  • Forums
    New posts Featured threads Search forums Members list Members map
  • Guides
    New guides Latest reviews Series list Search guides
  • Downloads
    Latest reviews Search downloads
  • Garage
    New vehicles Latest content Latest updates Latest reviews
    Series list Search garage
  • ePER
  • Events
    Monthly Weekly Agenda Archive
  • Gallery
    New media New comments Search media
  • Classifieds
    New listings
  • Directory
    New businesses Latest content Latest reviews
    Brands Search reviews
  • Shop
    Latest reviews Search products
Log in Register
What's new Search
Search
By:
Advanced search…
  • New posts
  • Featured threads
  • Search forums
  • Members list
  • Members map
Save up to 15% with Adrian Flux insurance!
Menu
Log in
Register
Install the app
  • Guides
You should upgrade or use an alternative browser.
Pollen filter - how to remove
Stilo  Pollen filter - how to remove
  • Thread starter Deckchair5
  • Start date Feb 19, 2006
  • Replies 21
  • Views 197K
Guide Gallery Discussion
The pollen filter is meant to be changed at every service interval but it's only done as an additional customer expense and not included with the service. It really gets surprisingly clogged so reduces heater blower efficiency.
Next page: Location of filter and removal of panel >
  • Thanks
Reactions: Ralf S., 12[X], Peat and 14 others
  • 1
  • 2
Next
1 of 2
Go to page
Next Last
C
ChrisMClark
Patron member
Parked in the garage Written a guide
RAF Henlow
  • Sep 16, 2007
  • #2
Newer pollen filters (according to eLearn) are actually snipped on the top and bottom so they can be folded to facilitate easier removal and refitting, and older filters may be snipped manually to aid this too. Tried saving the images but they save as some strange format so I can't post them up :bang:
  • Thanks
Reactions: shaggy100
Stilatos
Stilatos
Written a guide
Glyfada, Αthens
  • Sep 17, 2007
  • #3
Got this from a bosch filter i put hope it helps even more
  • Thanks
  • Like
Reactions: Peat, zebraman, rjcasey and 3 others
johnson550
johnson550
Fiats since 1973
North East
  • Dec 16, 2009
  • #4
Its best to put some cuts in it to help make it curve without twisting it.
  • Like
Reactions: FiatStilo2001
J
jim cooper
Patron member
Bangor, County Down
  • Jun 7, 2010
  • #5
Changed mine today (2006 1.4 16v active aircon 5 door) and can confirm you need a 5.5mm socket, preferably 1/4 inch drive, to get the little screw out of the cover hatch of the filter. Also you would need to remove the plastic tray that stops assorted wiring falling down onto your feet from above the pedals. This has a side piece which obstructs the slot that the filter goes in and it is impossible to move it out of the way. The tray is only held by two plastic press studs and they will break when you prise the tray downwards. Dont worry, they are easily replaced with the type of button stud that you can get in packs at Halfords. Snipping the filter as previously described is still necessary in order to get it round the clutch pedal and steering column.
  • Like
Reactions: eairlie
J
jqx81o
  • Jan 26, 2011
  • #6
hi tried removing the cover next to the clutch pedal but the screws / fittings were just turning when i was trying to undo them. are they clips , screws plugs. any help would be good because i'm not getting any air out of the lower vents.
Davren
Davren
Moderator
Staff member
Uploaded 10+ resources/downloads
London, UK.
  • Jan 26, 2011
  • #7
The panel is held on with plastic fir tree clips similar to this one. Give the panel a sharp tug and they should fall out.
  • Thanks
  • Like
Reactions: jqx81o and Settler11
J
jqx81o
  • Jan 26, 2011
  • #8
that's great . thanks. do i need to replace them with new ones after wards.(y)
Davren
Davren
Moderator
Staff member
London, UK.
  • Jan 26, 2011
  • #9
Providing they don't break, you can use the same ones again but after a few times they may become looser.
S
ScouserInExile
  • Oct 1, 2011
  • #10
Mioght sund like a silly question, but in a RHD drive car, which side is the filter on?
Davren
Davren
Moderator
Staff member
London, UK.
  • Oct 1, 2011
  • #11
The filter is in the same position for RHD and LHD cars and is accessed from the right side (when sitting in the car) of the center console.
B
bbrm
Coventry
  • Feb 23, 2013
  • #12
Completed this today using this guide and all I can say is, What a MASSIVE difference!! There was almost zero airflow before hand and the filter itself was completely disgusting with loads of hair and twigs etc. It was completely filthy...
It is a tricky place to get to but I found that using a ratchet and screwdriver socket attachment worked well. All in it took about 30 minutes and the filter cost a fiver… Worth a million pounds in improvement!
Cheers for the guide lads! :D
A
alex298
kings lynn
  • Mar 8, 2013
  • #13
The 2 fasteners on my abarth, on the drop down panel, if you push the centre pin of the fastener with a small screwdriver they pop out
E
erryn
  • Oct 12, 2013
  • #14
Just in case anyone with a UK (right hand drive) vehicle struggles:
The filter cover is right at the very back of the footwell on the driver side, I looked at it blankly for ages because it's quite well tucked away. There is a little bolt that you need to remove first, and you could probably do with taking the overhead wirecover off (above the pedals), but I'm not sure its absolutely necessary (didn't seem to be too much in the way)
The filter itself is very easy to replace though, took just a couple of seconds, once I found the cover that is! :)
Honestly hope this helps, as the diagrams didn't really point to where exactly it was.
Davren
Davren
Moderator
Staff member
London, UK.
  • Oct 12, 2013
  • #15
The photograph on page 2 of the guide shows exactly where the cover, and the screw and clips that hold it on are.
E
Esaus
Sweden
  • Apr 9, 2014
  • #16
I went to replace the pollen filter since I had weak airflow from the vents. Turned out that the plate covering the filter was missing and half or more of the airflow blew on the inside of the footwell. Had a bunch of leaves all over there. Some smuck had left the plate out. Had to use ducktape to seal the hole after I replaced the filter. Now the fan blows 100 times better!
:D
S
Settler11
Patron member
  • Sep 3, 2014
  • #17
Hey, I've been trying to remove the panel on picture 2 but I can't get it off. Those screws can't be removed with a screwdriver so do I have to use force or is there a quick way of removing them?
dannychapman
  • Nov 17, 2014
  • #18
also a good idea to spray your favourite aftershave on the filter itself so when the blower kicks in is nice smelling breeze :)
  • Like
Reactions: Ralf S.
S
Stub Mandrel
  • Jun 28, 2017
  • #19
What the above description doesn't include is that to remove the trim, cover and extract the filter you have to put the steering wheel right up, jam your head down by the pedals and stabilise yourself with a foot either side of the passenger headrest...
Of course getting yourself back out is the really interesting bit :D
  • Like
Reactions: Ralf S. and wody21
P
percydnb
  • Mar 26, 2018
  • #20
very informative. thanks
  • 1
  • 2
Next
1 of 2
Go to page
Next Last
You must log in or register to reply here.
Jazbee
  • Guide
Panda 2012+ Airbox to Engine Intake Seal
  • Jazbee
  • May 24, 2026
153
May 24, 2026
Jazbee
Jazbee
chevychase
  • Guide
Punto (Mk2/2b) Adding One-Touch Window Control to Passenger Side
  • chevychase
  • Feb 26, 2026
1
509
Jun 8, 2026
chevychase
chevychase
T
  • Guide
Ducato (Gen 3) How to determine if my engine has been deleted
  • theoneandonly
  • Dec 5, 2024
767
Dec 5, 2024
theoneandonly
T
Kahcorp
  • Guide
Ducato (Gen 3) Ducato 2014 3.0 180 multijet remove Manifold & EGR
  • Kahcorp
  • Mar 26, 2025
887
Mar 26, 2025
Kahcorp
Kahcorp
Pugglt Auld Jock
  • Guide
Miscellaneous Cheapo jump leads - how to "improve" them and use them
  • Pugglt Auld Jock
  • May 22, 2024
2
28
3K
May 24, 2024
chris3234
C
Share:
Facebook X (Twitter) Reddit Pinterest Tumblr WhatsApp Email Share Link
  • Guides
  • The FIAT Forum
    fiatforum @fiatforum
  • About The FIAT Forum
    The internet's #1 online community and oracle for all things FIAT since 2002 - if we don't have the answer, no-one does! Ask questions in the forums, fix common issues using our helpful guides, upload your photos to the gallery or buy and sell with the online classifieds.
  • FIAT Forum
    • Forums
    • Gallery
    • Downloads
    • Search
    • RSS RSS
  • Members
    • Log in
    • Register
  • Site Help
    • Contact us
    • Advertising
    • Terms and rules
    • Privacy policy
    • Help
Community platform by XenForo® © 2010-2024 XenForo Ltd.
Proudly hosted with by endrop.
