Technical  Pollen/Cabin Filter Location
Wrexham, North Wales
I suspect this question can only be answered by someone (Fiat technician or similar).
Where is and how do you change the pollen/cabin filter.
Please, no speculation as I've already examined the obvious places that are easily accessible.
I could really dig and de-trim deeper but instead of blindly pulling the car apart I'm looking for definitive facts.
Assume r/h drive is just the opposite ( not a fact I concede)!
Thanks for this.
I did look behind the glove box (via the top) and could not see the filter housing cover. Could only see the dreaded YELLOW of the passenger airbag...(boom :) )
Looks like one of the easier ones to access, on a previous car the Dealer used to charge for its replacement but it never happened as it was so difficult to get to. Once I took the car to an Indie, they showed me the original pollen filter they took out, 4 years old and absolutely caked!
Hi Changed mine on my 500x its behind lower glove box watch out as the clips break easy
Yes just done mine. Interestingly UK cars do not appear to have the bracket as seen in that video over the Filter cover (unless mine is missing!) Whenever you change your pollen filter always pop your hand in to the top of the fan and make sure there is no leaves/twigs or debris inside. Mine was making a horrible hum which made the whole dash vibrate slightly. It was only a couple of leaves in there but made all the difference. Ditto what Terry says above - broke one of mine but screws hold the unit in place ok.
Just done this on a RHD 2017 1.6 Etorq Popstar. The cabin filter is behind the glovebox. Remove the triangular side trim panel to the left of the glovebox (just pops off). Remove the 2 fir tree style trim clips holding in the carpet below the glovebox. Remove 5 T25 Torx screws. The glovebox pulls out.
