Technical Please tell me where I can get this square block/nut from?
Jev88
Peterborough
Apologies if this posts twice.
Need the square block that takes two bolts on auxiliary belt slider.
Probably not available as a seperate piece- if you have a drill (and maybe some taps) you or someone you know could make one? It looks to be a metal cube with 2 bolt holes thru it to take bolts one tapped (maybe M8) for the long adjuster bolt, the other just a plain hole for the lock bolt. If the whole thing isn't too dear, and is available, just but it before you wished you had, lol!
What's wrong with the sources on the other thread you started on the subject
It's a bit impolite to open a new thread because your fussy, fiat didn't make the part they bought it from lucas, valeo or magnetti marelli. The part I linked to you is still on ebay.
