Technical  please help with log multiecuscan
thomas35
greece
Hello guys. I think the car is not working properly. I have recorded a file from the multiecuscan and I want you to see it so that the fault can be found. The car is punto evo 1,3 multijet 199B4000 . Thank you
Model
punto evo multijet 1,3 85hp
Year
2011
  • FESExp_2508272107_Fiat Punto Evo 1_3 Multijet 16V_File3.csv
  • FESExp_2508272138_Fiat Punto Evo 1_3 Multijet 16V_File5.csv
Hello. The car has low performance. Also, the turbo pressure tried to rise above 1 bar but I think something cut it off. Normally, the turbo pressure value should reach 1.3 bar. Also, the maf sensor does not rise above 500 at full throttle. I have installed new injectors and changed all the vacuum hoses. The injectors were coded in the ECU normally. I have checked the VGT manually and I do not see it sticking. I have tried a new maf and map sensor and it still does the same thing.
