Technical  Plastic screen on instrument cluster
Tipo19GR
Hello all,
I am not sure how it happened but the transparant plastic screen that sits in front of the instrument cluster to protect it from dust is broken in my Tipo. Does anyone know if this can be replaced without replacing the complete instrument cluster?
I also wonder whether the 1.4 i.e. engine with injection has a hot air intake hose. There is an empty opening on the back of my car's air filter and also on the exhaust manifold, but no pipe that connects the two. Is that normal?
Hope you know more than I do :D
Thank you for replying :)
I sure have the dials. Will look up on eper.
Would you reckon the hot air tube is superfluous?
No problem :)
Hot air tube .. it has a benefit in winter.. but of no use now ;)
( it uses a Flap.. within the airbox to control flow.. dependant on temperature
If flap doesnt move with temperature.. then the hose is redundant )
