In the Bravo is standard inlet box and panel filter, outer air temperature was about 32-33 Celsius.
Can't adjust spark advance, completely controlled by engine electronic
Fuel quality is not so good, but other cars don't have same problem
Compression ratio is 10:1
No turbo
Chamber design, well, other Bravos don't have same problem
Carbon Build Up/Hot Spots, it is possible. I can tray to clean it
Engine is on the normal running temperature and fan was activated as should. Actually, pinging can be heard before car reached running temperature.
Spark Heat Range is correct
Lean AFR, I checked the spark plugs and lambda sensor and colour is correct. I did not find air leak
