General Pictures of stilo factory fit xenon's any one
Paul Westhead
Liverpool
I've been trying to find a picture of the stilo xenon headlights as fit from standard at the factory and i've had no luck. COudl some one see if they can find any pictures of these, or can some one take some pictures and post them up here? I'm after them both turned on and turned off
Cheers lads and lasses
Paul
Alright stuart,
urm.... the reason apart from hte fact that i'm curious is that there's a variety of xenon light i.e you can just get xenon bulbs which are different to the full xenon unit I am trying to extablish which ones that FIAT use, as if they only use bulbs i won't be adding these to the options list ;)
Ah, FIAT do not just use the bog standard Xenons you can buy from Halfrauds.
Look back at an old Ulysse thread - all the info in there about the bulbs/units they use, and the expense of replacing them
Cheers stuart, although this doesn't quite answer what i'm after a picture would be so much easier cheers any way ;)
:bang: :bang: :bang: :bang:
Yeah, true, just pointing out fact that Xenon factory fit options are a whole different beast to the xenons you buy at the local shops!
Plus you get pop-up washers - cool :)
I know they also look pretty as well :p
So whats the chances orf a few pics ladies and gents ?
I have Xenon but in my pics you would not notice any difference with normal lights as my pics quality is very poor.
I can answer all questions if needed.
I have found this pic but this not my Stilo: as you can see the difference during the day is minimum with normal lights except the blue parts and the hidden washers. You cannot notice the inside parts in this pic but you should be able to see the hidden washers.
Pic is here but you cannot see well.
I can tell you that live is nicer, you see a couple of blue parts inside the lights, one small plastic washer below each light which I did not know was even there until I found out one day so it is very well hidden within the front bumper. (y)
Hope this helps.
I did not know that...calm down guys!
To be honest I do not know if there is a difference with normal lights if you just look at them during the day except for the washers, at night is easier and you will definitely notice the Xenons.
During daylight I do not know if there is a difference then.
:eek:
We all have the blue bits, sorry, sorry, sorry! (y)
