Just began a course on hardware and software more affectionatley know as the A+ Course and will be doing an MCP in Windows XP afterwards.
So I am going to pass on all the little tips and things I come across which you can do to eek out every little last drop of performance from your PC but WITHOUT OVERCLOCKING!
So here is the first one and apologies for the more PC literate readers who know this already!
OK, Paging File - The computer uses this when it gets to the end of the physical ram you have in your system, the size of the file should be 1.5 times your physical ram i.e. for me it would be 1.5 x 1024MB (or 1Gb!) which is 1536MB now this can be found here (This is in XP BTW) START>RIGHT-CLICK MY COPMUTER>PROPERTIES>ADVACNCED TAB>PERFORMANCE SETTINGS and down the bottom so check the size and if you have more than one HDD change the location of the file to the hard drive that DOESN'T run the operating system and you should get a little extra!
Liam
Liam
