Patching Paintwork advice
first of all, can any1 recommend a Retailer or website which can mix up a specific colour for my Punto ([FONT=Arial, Helvetica, sans-serif]Azzurro Astrale - Azure Astral (804a)[/FONT] A light Blue)
I've heard of Paints4u - are they any good?
The Roof Box Mount on the passenger side has rusted - and i've got to stop it before it gets worse
Going to dremel out the roof mount as its rotten :( Going down to bare metal as thats only way to avoid rust coming back
Once i'm at bare metal - i've got to Primer - Colour - Lacquer the area i've removed
Is Halfords Primer Grey Okay? or do i need White?
Obvs then going to need the Correct colour
And then Some Lacquer - Halfords Clear Lacquer okay?
Any Advice would be appreciated - if you'd like to see piks, then i'll try and get some so you can see what i mean
Ziggy
i had the same problem with my stilo a while ago, i just ebay after typing in my colour name code got it mixed and its a perfect match, i personaly went with the white primer as i colour coded my wing mirrors with the grey primer and they turned out to dark for my car as the paint is a very light green, go with the white primer .
I've also had this trouble with mine so i've got to respray my baseplates.
rst is like cancer, the only way you will get rid of it is to cut it out. rust treatment only holds it bck for a while.
ay paint supplier will do your paint, your better off going to your local supplier than an online store incse your colour match is out
