Popitinpete
- Joined
- Sep 1, 2021
- Messages
- 292
- Points
- 142
Jock could I ask you for some help, and you daveMct if you read this or Indeed anybody.
Finally sorted out my erratic idle/poor economy/ surging under load and hesitation.
No EML on and no codes stored, cleaning out the inlet manifold of oil and cleaning the MAP sensor helped and replacing the split breather hose on the rocker box helped a little but I've actually found the root cause.
Between the alloy throttle body and where the plastic manifold join together there is a bright green 'O' ring / gasket / seal.
Mine has lost its squashability and now actually sits below the level of the trench it sits in, the alloy throttle body and plastic manifold don't provide a perfect seal without the green seal providing the actual seal.
Shop 4 parts don't list it but could you have a look on your electronic 'microfiche' please and try to get the part number please.
I've temporarily used soft blue hylomar to eliminate the leak and the car now runs absolutely fine, obvs this is just an elimination process but I want to put a new seal on. Its the one in the image below circled in yellow
2009 1.1 169.active eco.
Thanks in advance
Thanks in advance
