Technical Part name, only part I need ?
DrChoda
Dublin, Ireland.
hey all, thanks for the help in my previous posts.
got the connectors at the back done, and got the interior trim off the rear hatch very easily, via someone's reply.
What I noticed was the back windshield fluid hose was disconnected.
I reconnected it.
Here's the new problem.
No fluid comes out of it, but that isn't the big deal. When I tried the front sprayer, nothing came out.
Popped the hood, tried again and the the fluid was squiriting out from the engine side of the hood.
The piece that splits the single hose coming from the reservoir into 2 connections that lead to the hood nozzles. That piece is broken, as it just shoots out the bottom. It is on the underside of the hood, divers side.
What is this piece? And if this is broken, is there something else that would cause this that I should be checking for. Or is this it.
I'll worry about the rear wiper when I get the front ones done.
Any insight is appreciated as always.
Thanks again.
(if u need anymore info, I'll check back in a bit and reply.)
just go down local scrappy, that way you know what you want but dont have to know the name!! it's such a small part they will prob even give it to you!!
