Id imagine the main fault/breakdown that would cause people to consider scrapping a Panda is the same that affects the Mk2 Punto - Power Steering motor failure.
At the moment most Pandas either seem young enough or with low enough mileage to get a contribution to the high repair cost from Fiat. However as time goes on, Fiat will stop contributing to the older/higher mileage examples and because the cars value will be dropping at the same time, people will decide it's not worth spending £700 to repair a car worth £1500, for example. Not that Pandas are that cheap yet, but just as an example.
They may suffer from abit of scabby surface rust on the underside or exposed parts, but even with economical build, i don't see the Panda suffering from major corrosion issues.
Alot of the other issues with Pandas arn't really expensive enough to fix to warrant scrapping, so it'll probably be just the usual case of people giving up on them for something newer, like is the case with many scrapped cars today.
