Technical Central locking system will not lock left hand rear door after full lock replacment.
UK
I'm having a little problem, after replacing the locking system "on the left hand side rear door". on my fiat panda city cross, the rear left hand side door lock will not lock?, all the other doors lock just fine apart from this one, maybe the lock needs ajustment?.
Ant help wuold be greatful.
Model
fiat panda city cross 4x4 09 litre
Year
2020
Mileage
20000
Did you just work on the drivers door
Does it lock from the lever inside
Can you see the lever trying to move when the remote is pressed
Open and close the door a few time
Your cars a 2020 this section is for pre 2012
Didi not realise this section was for pre 2012, firstly its the rear passenger side door, and no I have not checked trying to lock the rear dor from the inside, tried opening and closing the door a few times, I can hear the lock trying to catch but it dose not.
Check it from the inside lever
If it works but the lever flips back to the opening position the actuator inside has seized or jammed
