£999 Challenger
So a day of ups and downs for me. Starting with an all time low. I used P40 filler for the first time since I bought my first welder.
If I had taken the time I could have spot and popped the pannel straight but the £999 challenge isn't a concourse event I had a lot to do today.
First I needed to get the bonnet M.O.T friendly so cut away the holes in the front corners (sharp edges) and filled with new metal.
To make up for my P40 indiscretion I used a safe amount of welt so I could grind and flap it back...
...and a little filler (Grrrrr!) to tidy up the flap groves.
Okay before I go on. I hate filler! The guidelines suggest you use a pea of hardener for every golf ball of the stuff. In my opinion (sorry I this causes any offence) if you need a golf ball of filler you haven't done enough metal work and should give up and start again.
So next on my list of things to do was door number two.
Seam welded along the top and stitched the bottom lip.
Grind, flap, fill, sand, fill, sand, fill, sand, wet and dry, prime, paint, leave to dry and re-hang.
I also finished of the rear quarter filling and tidied the passenger door.
While I had the filler out I finished the bonnet and refitted it.
In other news the belt arrived so.....
....ladies and gentleman....
....boys and girls....
....I present to you...
...the Fiat FINE engine.
I cranked the engine by hand and the TDC marks lined up perfectly every time. So in theory at least the engine should work.
