£999 Challenger 2013?
Kev' Van of Death said:
Are you feeling exhausted today?
me said:
First off today I had a bit of a problem to solve...
...the pipe from the water pump fouled the exhaust manifold. After a bit of fine tuning with a rubber hammer...
...solved. So a bit of fabrication later and I have the pleasure to introduce you all to...
...Frankenzorst! Punto 75 manifold and shortened down pipe with the "S" piece turned ninety degrees so it clears the bottom of gear linkage, a length of mild steel pipe I bought from work for £1, the centre cherry bomb from the Guff racer, modified rear pipe from the original Panda 750 box and finally the Stainless Steel Longlife back box from Guff I paid a fifer for last year. The pipe was six inches too short so I added the centre box to make up the length and give me an off cut of pipe to use later.
First trial fit...
...clears the linkage nicely.
Clears the selector box as well.
Clears the Omega rear suspension and...
...lines up with the centre mount perfectly.
A little low up front...
...but looks pretty good from the back (if I do say so myself).
At the lowest point I'll add an extra couple of exhaust clamps with titanium nuts to spark when it grounds out. If I go for fourteen inch wheels I can lower the car two inches, on 13's I can only drop the car 40mm at most.
