Technical  Panda Towbar & Electrics
decosta1228
Ledbury
I want a tow bar fitted to my 05 Panda & just want to check that I'm going to buy the right equipment -
Towbar
Electrics
Does anyone have an specific Panda fitting instructions or is it the same as fitting a towbar on most other cars?
Thanks.
I thought to use the plug in kit you still need a connector to enable it to work, which isn't available from Fiat unless you buy the complete kit from them. It will enable power to be put onto the output of the module on the bumper, as I believe it is not live if you check. I may be wrong and hopefully I am as this is all that is putting me off fitting a towbar to my MJ, as I can't see the point in scotchbloking in the boot to enable services.
