If you reference this quote you should also reference the correction in post 12...You also wrote this:
"as removing the DMF makes the syncro's in the gearbox wear prematurely as they have to brake the whole mass of the crank and flywheel rather than just the secondary mass within the flywheel."
But surely the issue is that the twinair (TA) or anything less than a V6 design is inherently less than perfectly balanced in the first place? I think I will go with the evidence presented. I have a 100+k miles TA two DMFs later that still has its original gearbox.DMF's did not resolve early transmission failures, even today a Panda is fortunate to go past 60,000 miles with one.
The transmission failure was down to weak ball bearings, the Fiat cure was to fit much stronger roller bearings.
The weakness in the ball bearing cage I submit was exposed by the input shaft experiencing excessive vibration originating from prematurely worn DMF's.
I still maintain that a half worn, unbalanced, insecure DMF (say covered only 30,000 miles) causes far more gearbox damage through transmitted vibrations, that a perfectly balanced (for it's whole life) single mass flywheel.
Here's a photo Ben took earlier...Its quite exciting when the DMF's fail as they chop the end off the thrust bearing guide!
I suspect you have to have a very unsympathetic "mechanical" ear for it to get that bad? Or a very loud stereo?Its quite exciting when the DMF's fail as they chop the end off the thrust bearing guide!
You are talking about second order vibrations, where the crank is at 90 degrees to top dead centre and the pistons are slightly more than 1/2 way down the bore , causing the imbalance, due to the angle of the con rods. In the 1750 engine they deliberately used longer con rods to alleviate this problem.But surely the issue is that the twinair (TA) or anything less than a V6 design is inherently less than perfectly balanced in the first place? I think I will go with the evidence presented. I have a 100+k miles TA two DMFs later that still has its original gearbox.
Once they fail they seem to do this extremely quickly, 30-40 miles or less.I suspect you have to have a very unsympathetic "mechanical" ear for it to get that bad? Or a very loud stereo?
Chalk and cheese mate, 99.9% of Pandas will only ever see a race track car park, if that!We have found that with the race cars that removing the DMF will kill a gearbox in one or two races!
Chalk and cheese mate.We have found that with the race cars that removing the DMF will kill a gearbox in one or two races!
I hate to think others will think I have a strop on, I DON'T.If you reference this quote you should also reference the correction in post 12...
Panda 2012+ - Panda raid, what do you think?
Fiat workshop submitted a new vehicle: Panda raid, what do you think? Read more about this vehicle...www.fiatforum.com
My sons Panda 4x4 TA did 180,000 miles on its first dual mass flywheel before it did the gearbox munch! So I suspect there's some luck in there somewhere.Chalk and cheese mate, 99.9% of Pandas will only ever see a race track car park, if that!
Race cars are virtually rebuilt after every event anyway, so no big deal.
I'll wager that no where in their original sales blurb did Fiat proudly announce that their Panda's clutch is a consumable item, that WILL require replacement every 50,000 miles!
I have left the 'dark side', seen the light, and gone single mass, time will tell, BUT I reckon with this uprated bearing gearbox and solid flywheel setup, it will outlast many DMF's!
About 115k here on a multijet 4x4 before you told me to change it.My sons Panda 4x4 TA did 180,000 miles on its first dual mass flywheel before it did the gearbox munch! So I suspect there's some luck in there somewhere.
Yes you did rear that right 180,000 miles, the twin air unit gave up at 150,000..
The power of the Capitol @Bonefish BluesOne person has made their OWN decision, based on their experience and ANALYSIS.
Arguably (because everyone argues here!) the country's leading specialist counsels DIFFERENTLY, based on LIVED EXPERIENCE of hundreds of these vehicles.
Time will tell.
I JUST LOVE this new vogue for USING CAPS to strengthen MY ARGUMENT.![]()
Maybe I should get you to do this to my MJ - it’s coming to you on 5th May anywayIts a lightly breathed on TA, I do fancy doing a Multi Jet but I would really like to fit a 1600....
The parking sensors will help when that tree gets a bit close.
I love the tyres they really work well on the green lanes round here!
Zooming in on the Fiat Workshop’s photo… are those the Ziarellis? I think they areLooks class.
What tyres are fitted?
The only proper off road tyres in Panda size that I've been able to find so far are Ziarelli Mud Power, which look good and I've heard ok things about, but wow are they expensive to get hold of in the UK.
There's more here https://www.fiatforum.com/threads/my-panda-4x4.504202/post-4738640 and I vaguely remember a contribution on here from a Polish guy/girl who was talking about tyres (off road) but I don't recall the thread.Zoom in… are those the Ziarellis?
