Hi all,
I have a 2008 Panda Multijet which I've had since January 2017. I've got an issue where it keeps not starting...
I took it to the garage and they said the found the issue, that the battery was not holding the charge (which I suspect was not true) so they fitted a new one, also fitted new camshaft and crankshaft sensors. But its still happening.
In the morning it starts fine, no issues and runs perfectly, then when you stop and try and start again nothing, it doesn't even try to start.
It's possible to push start it, so I don't think its an issue with the immobiliser which I first suspected. But seems to also happen randomly in that it occasionally starts again after stopping but then the next time not again.
So a couple of questions, looking at other similar threads it could be an earthing issue - but could this still be the case if its starting sometimes and not others?
Also, possibly a loose electrical connection somewhere?
Once it wouldn't start and I turned everything off (I think at the time it was only the lights on) and then started, so I also suspect it may be something is draining the battery when it's off - if this was the case though wouldn't other things be affected? The lights, radio, dash lights etc etc all are totally fine it seems only the starter motor thats not getting any power.
The issue seems to be mainly after its been driven for a bit - annoyingly at the garage by the time they look at it its starting again, but I'm guessing they are just switching it off and on again!
It's in the garage at the moment and they are waiting for the electrician to come and have a look, but its been 3 days not and they keep saying he is coming tomorrow (and then he doesn't
) - can anyone recommend a good garage in North London (or within 40mins or so) that I can take it too? It's currently in a Halfords Autocenter, only because they did the aircon just after it started happening but I'd rather take it to a local garage.
Thanks in advance!
Thanks in advance!
