Technical  panda ABS light on
Panda Active 2006, had problem with rear brake adjusters recently, all back together now and seems to work fine but ABS light is on now. Do the drums have ABS sensors attached? If so, whereabouts are they and how do they work so I can check them?
Read the fault code..!! :)
With your blown fuse..and other issues
There is a fair chance this is erroneous..
And certainly no guarantee it is a symptom of work recently carried out on that corner.:(
There is normally a rotor and sensor ;)
Apparently its the oldschool sender in bearing:
https://www.fiatforum.com/panda/463442-abs-warning-light.html?p=4370162
Charlie
the sensors go through the backplate and pickup from the bearing,its real easy to break the sensor when doing rear brakes on these especially if the adjuster has moved
not too dear to buy,ka mk2 are the same i believe
just looked they have gone up,sure ive got some ka ones if they are the same, i will try to look in over the holidays in case they are and you need one
