Line up the crank timing marks as well!!
i still can hear a knocking sound at idlle...
Alterlego
Doesnt mater how the belt is fitted. on the top wheel(cant think of name) there is usually a small dot of paint. perhaps red. there is a mark on the head to. little chip out of it. line these two up and then fit belt. timing should then be properly adjusted.
If someone has a guide to timing adjustment please upload to help Alterlego.
Well i made sure that the mark on the flywheel was at Oº (zero degrees), cause i didnt take off the alternator pulley, but i think that doing this is the same as lining up the crank pulley (at 10 o`clock) right?Line up the crank timing marks...
Hi Alterlego......
I think that knocking sound at idle comming from valves adjusting. Think that is a situation because valve adjusting tails is too thin and then you hear the knocking. If you done belt wrong - you will hear lot of terrible noises, like combustions, and engine will try to excape from the engine bay....
So I think you only need valves adjusting....
Hi guys:
Can please somebody help me understanding why panda radiator cap works the way it does???
Cause panda seems to get hot, very fast (2 to 5 minutes) and i can feel the heater blowing very hot air, very quickly. (thermo is new; coolant is new; water pump is new also, and no airlock).
Last couple of days when stopping the car i could hear a whistle coming from the radiator cap (too much coolant pressure exiting), so:
1 - if the radiator cap is dead, should it release pressure? or that means that its doing is job?
2 - But too much Pressure means coolant is boilling, maybe because radiator cap cant retain pressure inside, lowering boilling-point (maybe that killed the head gasket).
Never in the past (except before head went) the cap loosed pressure, at least that i could hear, and i never found the culprit that killed the gasket.
Why is it loosing pressure again...schiuffffff.
Cheers (schiufff, schiufff)
Alterlego
I dont have a stroboscopic timing light to set the ignition in a dynamic way, so i did it in static mode (engine stoped, so no need to plug vacuum advance tube) set it to 2º BTDC.Well Alterlego........
First of all I attached two pictures, one for timing adjusting and one for testing ignition coil.
So as per attached pic, ignition coil for your engine code, shoud show following measure (use multimeter-ommeter) 2,4 - 3,3 ohms at primary coil and 3330-4070 ohms (3.3K-4 Kohms) at secondary coil. This is not too hard to check if you have multimeter. (Hot ignition coil seems to be cracked coil)
Second, I suggest to check orientation of your thermostat (may be it is counter oriented) so engine become hot too fast because coolant flow to the radiator is stopped - by wrongly oriented thermostat - they do not open properly (even its new). See pic below
Aca
I gotta run the car for 100 kms before flushing out the cooling system cleaner i put inside radiator yesterday. but i remember having the same problem (quantity) of coolant that the system needs. I read somewhere is 5.5 liters to fill it up. I could never fill it with more than 4, wich i presume must mean that there is an airlock inside (even considering the top hose is empty when bleeding sytem).You got the right amount of fluid in the system?
to much will reduce volume for steam and the only way out is trough the cap. try draining some out and see if it still over heats.
[/quote]If lead standing in hot weather, i suspect it is where you are! then the engine is going to get hotter faster than before.
Hi arc:when the head was skimmed, was the camshaft removed? If it was, have the shims gone back in the correct place. They wear at different rates and it is important that the clearances between the shim and the camshaft are correct.
Hi pandamaniac:...The idle consistency improves once the engine is warmed up to operating temperature.
This is also the same cylinder that tends to go when the head gasket goes.
Hi Xsparky:...lean running - possibly an air leak which might also account for the poor idle - did you remember to reconnect the vacuum tube on the dizzy?
Hi aca:Think there is a larger gap between camshaft and valve adjusting shims inlet and outlet too- and think because of that you can hear that `chain rotate` sound.
