Technical Panda 1.2 changing thermostat,worth doing stiff clutch slave cylinder,same time..?known problem..
Hi all,found excellent vid on utube,usual problem,thermostat stuck open.recommends going in by taking out battery box..so be it,have new thermostat,eBay,9 quid.questions are..85 k ,district nurse battlescarred taxi stylee,clutch pedal getting a bit stiff,have recon slave cylinder..worth doing at same time,or opening can of worms.?up to it mechanically,as in younger days,changed whole engines,insprites,mk 1 cortina’s,but a lot more room to work in the engine bays..!plus plastic clips wears,things go ping!and can I drain a bit off the rad..pristine new driveway..wife would kill me..ha ha.ps,who designed the opaque inaccessible coolant tank…
If you don't do the slave get some red rubber grease and pop the seal off the end and stick some in
it will help, did mine about 2 years back it freed it off and it has stayed free.
You can do it by feel from under the car but if the battery tray is coming out.
Stiff clutch pedal
Worn out clutch normally
Squeaking and or pedal not returning
Slave cylinder normally
But nothing is garenteed
I would measure the release arm I posted the correct measurements awhile back
Or grease the slave and see if the problem improves
Stiff clutch pedal
Many thanks..and also..why is the coolant reservoir so badly designed,opaque,hard to fill …
Cheap I guess
I started out shining a torch at the side at night like others, along with peering down the top
And eventually settled on blowing down a tube while lowering it into the tank, when you hear bubbles that the level, works pretty good, quick and you don't have to wait for night
It is important not to over fill as well as having too little
Stiff clutch pedal
Ty,useful..
Cheap I guess
Ty koalar .these things are quirky..is there a drain plug on the panda 1.2 rad?I’ve got a whole refurb kit..and a new unused vaileo clutch.****,even to get the spark plugs out,mine have done at least 50k..deep..my friendly garage guy told me..beware disturbance of cheap plastic bits,,as said ,things go ping..
Ty for that,Ralph m..
Cheap I guess
I remove the cap and shine the torch down the filler neck, even in daylight it aluminates the inside and you can see the water level from the outside.
