Panda 1.1
Panda 1.1
I would be wanting to test that spark with MES.
Check wiring is plugged in. Remove plug from coils pack(s)and give it a wiggle to see if anything changes because of a broken wire. Look for any corrosion or broken pins.
Maybe try another coil or if you ahve two coil packs swap them and see of this restores the spark. Replace duff coil packs with new.
Good luck
this Panda model does not have an engine speed indicator and an IMMO light.. by turning on the ignition, the fuel pump is heard..
Does the oil can light come on at ignition on
Does the battery light come on at ignition on
Does the engine check light come on at ignition on
Do the stay on during cranking
