Technical Pain in the ASR !!!!!!
ROWENA
I'm with MR Ford
Pencoed south wales
Pain in the ESP !!!!!!
my ESP is playing silly buggers on my 02 1.8 dynamic 3dr, driving along normally i take a L/H bend and my ESP kicks in even on sweeping bends but not all the time it's driving me nuts :bang: R/H bends are fine it does this at low ,medium and high speed has anyone had the same problem I have checked my wheel nuts tyre pressure and for wear and tear and all is how it should be :confused: thanks in advance
Karl
Yes BBS took all the wheels off and checked all the mechanical stuff starting to think its the sensor but I dont know where it is or how to test it (n)
Karl
front 2 and rear 2 are the same argo all the same size 205/45/16 where is the sensor and can I test it as I'm a duffer as far as wiggly amps go :confused:
Karl
Karl
I'm just guessing really as I know the steering rack passes info about steering position back to the ESP control module so seems logical it needs to be centred properly.
Could still be a wheel sensor problem I guess due to the load on the bearing plus a bit of wear - but you'd expect that to be measurable :chin:
