retiredtechy
- Joined
- May 6, 2014
- Messages
- 5
- Points
- 1
Hi guys, about 6 months ago i carried out a routine service on my partners 1.2 500 (2009).
On taking the number 3 cylinder plug out i found the ceramic on the top of the plug damaged, i then spent a few hours trying my very best to clear the area of any ceramic and run the engine over without plugs in the hope that it would get rid of any ceramic that may possibly have got into the cylinder.
All went well and the engine ran fine...phew.
A few weeks ago the eml came on, the card idled badly and limits at about 4-4.5k RPM, which i assume is some sort of safe mode with certain obd codes?
Anyway. i got my scanner on the car and found fault code p0016 crankshaft.
I gave the car a quick check over and found that one of the ignition leads wasnt connecting well so have replaced the full set, issue remains. The backbox is also blowing slightly.
Are there any common issues that would put up this code i.e is either the cam/crank sensor a common fault? Could the blowing exhaust really be causing the fault?
Or....am i to suspect the worst and wonder whether the ceramic has somehow knocked the timing out? (i dont actually know if any got into the cylinder though).
Any help or guidance to possible causes would be much appreciated, thanks in advance.
