Old 24-02-2011   #1
Cool P0016 fault code came up on my t-jet
Hi guys .
I recently put new cams I'n my t jet and was running fine until this fault code came up . My car now only runs half boost and but then sometimes let's me run fall boost . I'm guessing it's a f""kd crank sensor . The cams are time as when diary put I'n fired up straight away doesn't take. While to start . I would like to no what it is ? Are these sensors normally dodgy ?
CNapperturbocrazy is offline Reply With Quote Quote
Old 24-02-2011   #2
Re: P0016 fault code came up on my t-jet
Quote Originally Posted by CNapperturbocrazy View Post
Hi guys .
Napper, use some grammar please makes it easier for people that can help you to fix the issue. Otherwise they may just take one look at it and go, I dont want to decipher this!
PS did you put the fast Road cams in and did they make a difference?
Thanks Vance thanked for this post
TallTom is offline Reply With Quote Quote
Old 24-02-2011   #3
Banned
Trader Rating: 2
Booth has donated!
Hi guys .
Some people on here from other countries use better grammar.
That didn't make a lot of sense.
Booth is offline Reply With Quote Quote
Old 24-02-2011   #4
Google the error code- it's a crank/cam sensor synchronisation error, ie, the two signals aren't matching correctly for TDC. It's a common error when the cam timing isn't right.
Who did the work, and did they use the official timing tools? Also did they reset the self adaptives and perform a phonic wheel learn after fitting the cams?
D4nny8oy is offline Reply With Quote Quote
(T) Yellow engine light on fault code p0016 jason trevor Ducato 8 02-01-2015 18:36
(G) Fault code / Error code list sporn Punto (Mk2/2b) 2 12-05-2010 16:49
(G) M-jet t-jet alloy wheel colour code Cooks Grande Punto 3 22-04-2010 10:44
(T) Fault code Greyhound_Shrops Multipla 2 07-03-2010 13:58
(G) My first serious fault T-jet. phil j Grande Punto 11 14-06-2008 04:45
