Hess
Hello again. I ran a few checks today as advised by a few of ye good people out there and came up with some sort of results but I'm still not sure about some things.
First off I looked at the oil cap and didn't find any white sludgey stuff, also had a look into the coolant bottle and didn't see any sign of oil so hopefully this is a good start. No head gasket needed.
I then started up the engine and had a look under the dashboard and there was a drop of cooling fluid (blue) hanging from the plastic casing - ok, something wrong with the heater matrix.
Next I went round the water pipes in the engine and found that the two pipes comming from the rad were hot but only one of the pipes going from the back of the engine to the matrix was hot. The one on the right was cold.
I then opened up the small plastic bung on the rad and got soom steam coming out. Done the same on the pipe at the back and got more steam and then some coolant so I closed it up. Not sure if I was doing this right, anyway the rad fan was kicking in every now and again and kept the temp needle between 1/2 an 3/4's on the temp gauge. After a while there was no sign of any fluid coming out of the rad so I closed up the bung, let the engine cool down and then topped up the coolant bottle (it was below the min).
This is where it gets a bit funny, I started it up again and went round the block to get it warmed up. Then checked the pipes and found that only the top pipe coming from the rad was hot, then noticed that the rad fan wasn't kicking in and the temp needle was heading towards red. I tried bleeding the rad again but got lots of steam and no coolant. So hear I am scratching my head. Have I got two-three problems here?
1) a dodgy thermostat that only works when the car is not moving.
2) a blocked heater matrix with a small leak.
3) an air locked radiator.
Sorry about the small book I've just written, any comments would be appreciated otherwise I'm left with a hot engine and cold feet...
