Technical Overheating sorted but other problems
PuntoBoy2010
manchester
hi all
my car just started recently overheating so put a new water pump onit still overheating took the thermastat out. no overheating now running fine till i stop and the injecter light comes on but if drive it with it on it gose off but comes on when parked up. but when parked up and light comes on it still running fine.
can any1 help
thanks
lee
Mk1 / mk2 / Mk2b
And for injector light can be a host of reasons why its coming on, without the fault code been read i'm not able to help much
But The light comes on - but it seems happy to run and rev?
Ziggy
hi mate mk1 ive sorted it now and ye was running and driving fine
Hope you put some proper antifreeze in there before this cold snap hit.
When the weather improves get the system flushed and chemical cleaned. It may well find a leak (probably in a radiator), but better to replace the rad than have a lump of gunk fall out of a hole and lose all your nice new coolant.
Re: problems again frigging fiat
the back gear box mount to the chassis had snapped so ive had it welded.
am doing ruffley 40 mph car is shacking all over the road. press the clutch in stops but i have noticed the passanger side ball joint has got play init. just woundring if any 1 could shed some ligh on this.
thanks
lee
