- Joined
- Feb 10, 2008
- Messages
- 25
- Points
- 4
Hi all ,a week since my 1st posting, changed thermostat ,then changed sensor,,have water coming out of both bleed valves,YET STILL THE ENGING IS VERY HOT and the Temp light comes on after 10 miles or so?? The fan works as Ive tested it with 2 wires to the battery but it has not yet cut in ?? The expasion cap just gives a little rush of air whan loosened and the water is hot but NOT steaming but it is a shi**y brown colour??HELP!!!!!Not sure if its ok to keep running it?? replies please P.S the ECU light is fine now and not been on since??Is there an easy way to wire the fan on permanent??? Thanks
