Hi everyone. I am very new to Fiat ownership and am experiencing this exact issue on a used 500 1.2 lounge I bought. I am also seeing a dim glow from some of the dash warning lights when the ignition is completely switched off. With the ignition on and the right indicator flashing, the engine warning LED and the ABS warning LED flash together with the timing of right turning signal LED. Keen to know if anyone has had luck fixing this without having to replace the entire dash cluster? thanks
This is a very commonly reported problem here. The usual solution to this problem is to repair or replace the instrument cluster. A different cluster to the one originally fitted will need programming to the car.
If you take the car to a franchised dealer, they will replace it with a new OEM cluster, and guarantee the work, but expect to pay £1200+.
Repairing the existing cluster is one good option; do a search on the 'net to find folks offering this service. You'll need to find a garage to remove & replace it (unless you can do this yourself), and you'll be without the car whilst it's away. This would be my own preferred way of sorting this, since the repair will fix the original inherent weakness and you know the rest of the cluster works fine.
Another choice is a secondhand one, but there's no guarantee that won't fail the same way in the future, nor that it might be defective in some other way. You need to find one that's showing a lower mileage than yours; it can be adjusted upwards after fitting, but not downwards. It also needs to be compatible with yours, there have been several variations over the years, and of course they're colour coded to black or ivory to match the trim option. Significantly cheaper than a new cluster, but not without risks.
You could also buy a new cluster from
shop4parts and have it fitted by an independent garage; just make sure they have the right software tools to program the cluster to the car.
Donate to the forum and you'll get a 10% discount on the price. This should save you about £500 compared to going to a main dealer.
You can just keep using it. Not sure if it will pass muster for an MOT, though. Probably depends on how obvious the issue is, and the tester's discretion.
