OT - What can I use as MDF primer?
dank_army
HI,
Does anyone know what i can use as MDF primer before i spray it? Daz you must know as your a joiner arent you?
Regards
John
any primer will do the job. spray on or bursh on, it's not critical like the bodywork of the car as it's not being subjected to the same environment.
Re: Re: OT - What can I use as MDF primer?
i think u need a cellulose sealer otherwise the paint will just absorbe into the wood and flake apart??? not 100% sure tho
chris
MDF primer, made by international. Red tin from B&Q, homebase etc..
Cheers guys, will have a look in b&q at the weekend
And ill post my pics of my computer case i made :) on sunday hopefully!
John
Re: Re: Re: OT - What can I use as MDF primer?
Daz aint a joiner but his mate Tafi is handy with a saw!
Re: Re: Re: Re: OT - What can I use as MDF primer?
acrylic primer undercoat should do, 2 coats.
it's water based and dries in about 15 mins or so.
yup am a painter & decorator. :)
simocuth
Re: Re: Re: Re: Re: OT - What can I use as MDF primer?
Cover it with glue, then primer, then paint...
It was on a DIY program this morning...lol
and no i'm not a joiner...but i am good with my piece of wood :)
Daz
Primer
Just about anything will do to prime MDF (emulsion's as good as anything) but the trick, esp if yr spraying it is to apply two thin coats and lightly sand after each one, as MDF will go slightly "fluffy" when u first paint it. Sand this off and you'll end up with a finish like glass when u spray it.
Re: Re: Primer
HI all,
thanks for the posts, ive been to b&q and got myself some of their mdf primer, and some matt black spray paint. Im going to try the sanding thing, and hopefull ill post pics tomorrow eve if all is well!
Thanks guys
John
K
2
1K
Dark Lurker
T
4
736
Insomnia
I
3
1K
Tommy K
T
T
5
626
K
