OT - DS Lite Vs Wireless router
R
Rich
Hi
I can't seem to get the two connected... although its meant to be possible.. does anyone know how its done?
1997 Fiat Bravo 1.6 SX
RUNNING WELL
Needs some cosmetic work;
-Need to respray front wing (Colour doesnt match);
-Could also do with a clean;
-Need new bump strips;
-Want new wheels.
The DS will only access routers that are only WEP secure and not WPA/WPA2.
Do a search for R4's for DS. Best thing ever. I've got one. Best of all got it from HK for £17 delivered.
The Bravo Stays!!!
As above.
Bought the little girla DS a while back then discovered the R4 card. Ended up buying myself a DS and R4, little lad getting one at xmas, Ali getting one at xmas, her daughter got em, and her other daughter getting the R4 card off me this xmas.
Get one with a 2gb card. Can run 50 or so games from it :)
so potentially you could download games and load them onto your card to play on your ds?
gareth
nice one, so i jus need an r4 card? i presume u need sum kind of reader tho to be able to connect this card to your pc? any one reccomend a good rom site
cheers
gareth
R4 card and Micro SD card. the bigger you get the more you can fit on. The R4 card also comes with a USB converter. You stick the SD card in one end and the other USB into your PC to transfer the files.
I got mine from dealextreme.com who now no longer sells R4's for legal compliance reasons. They however link you to an affiliated site.
Heres the link, postage is free if i remember correctly. Look at the link and you'll see what you get with the R4. As Wimmy mentioned you will need a memory card and the R4 comes with a Transflash to USB convertor. Google NDS roms and just drag and drop. Plug the R4 into the DS and away you go.
http://www.volumerate.com/details.vr/sku.1202
If you want to play GBA advance games get the EZflash V, similar thing but fits in Slot2.
Go on youtube and type in "R4 NDS" for what it does and how to use it.
The Bravo Stays!!!
M
13
349
Dark Lurker
A
212
Andy1.6hlx
A
M
12
496
M
T
7
572
Tommy K
T
