I've got one more idea regarding an engine swap...
Found this here...
http://www.ebay.co.uk/itm/Genuine-F...arts_Vehicles_CarParts_SM&hash=item232666e040
Pretty much a brand new engine. This I understand is a little more similar to my 1242cc engine?
As I'm lead to believe the 1368cc is a derivative of the 1242cc FIRE and the 1368cc Super-FIRE is what they went on to make into the T-Jet/ Abarth motors?
I may be rediculous in thinking this but I'm at least a little bit sure I'm onto something with this one...this engine will at least drop in with the Stilo 1.4 engine mounts, so...what if I'm able to run this off my 1.2 wiring loom and ECU and get it remapped to run the correct air/fuel with the turbo because - after the larger displacement and turbo - there's not much else that can be different right??
I assume this Abarth runs off a MAF sensor so I can do away with that with my ECU and probably fit a higher range MAP sensor unless the Abarths have MAP sensors as well?? I can't think of anything else that this engine would have on it that would need blanking out that my wiring loom/ ecu won't recognise?
That's basicly all I'm trying to do - make this engine compatible with my ecu and wiring loom - can't think of anything else that would need removing, although I don't have air conditioning so I'd remove the compressor and the drive belt and fit my 1242's belt in place
I can't think of anything else I'd need altered on the engine to make it run with my ecu/ wiring loom, if anyone else can I'd appreciate it
Just an idea at the moment, but seems a lot more feasible than my more recent idea I posted
Over and out
Mark
Found this here...
Over and out
Mark
