- Joined
- Mar 2, 2015
- Messages
- 542
- Points
- 160
I checked it at 63° - which is 20 below normal operating temp. I'd have expected it to be under normal conditions by that temp, but perhaps that isn't the case, and it is still running a warm-up?Should go closed loop when warm. Is your engine up to temperature?
It's not the heater than comes back as open-loop, it's the sensor itself. Voltage shows 0.0000v. I will check it at running temp at my next convenience.If it is the O2 sensor heating circuit that is faulty, the sensor will just heat up slower, so taking longer to give readings that will reduce fuel consumption.
If the output voltages were incorrect, I'd expect a warning light on.
Time to replace it sometime. Might be an idea to replace both, prevention...etc.
Mine is an '05 so I've got both. I did a quick check when I got home today, after a 15 minute drive, so water temp was as it should be, but post-cat o2 still comes back open-loop. I did however post 0.0046v reading in idle, so it is working after all.Understand the phrase
Open loop Readings = The ECU recieves the signal from the Sensor - but ignores it
it doesn't want it - it'll ignore it
Closed Loop = ECU recieves Signal - ECU processes data recieved - ECU outputs to required Devices (coils / injectors etc) - ECU Recieves new signal and repeat
The POST CAT sensor is After Catalystic convertor
The Cat takes time to warm up, before it becomes efficient
So the ECU keeps it in open look till it thinks its warmed up (timer or engine temperature reading)
The Heater elements DONT HELP THE CAT WARM UP
The Heater elements Help the Sensor React better to the flow of emissions
Even so - the post sensor once warmed shouldnt give a Null reading (0.0000v)
UNLESS you are of the many punto's that doesn't even have a post cat sensor
2003 onwards went to EURO 4 emiision regs so it got the cam and post cat sensor to help lower emiisions
Ziggy
good adviceSwap post and pre cat sensors over
There the same sensor
If the sensor thats giving poor/low voltage reading is still in the new place and the other one is giving a reading then its a duff sensor
Ziggy
