Ok, I'm putting together a new PC, and need a bit of advice. I've done this before, but not for a few years and the technology's moved on a bit!
What I have is;
Asus P5B motherboard
Intel Core 2 Duo processor
2Gb RAM
2 x Maxtor 250GB SATA2 Hard drives - I'm planning to use these as separate drives, not in a RAID configuration
Asus EN7600GS Silent Graphics card (512MB)
Antec Sonata II case
DVD+/- RW
New XP Pro OS
This is all brand new out of the packaging, so discs are unformatted etc.
I'm using my existing Iiyama 19" CRT monitor for the moment, looking at 20" LCDs. My old PC has a floppy drive which I can stick in the new PC if I need a floppy boot disc or anything.
So, I've assembled everything, double checked, hooked up the CRT to the analogue VGA O/P of the graphics card (it has DVI & TV out too), fired it up, and....well, it started, PSU and fans going, bit of hard drive noise, but no picture - it didn't wake the monitor at all. I had hoped I could go straight into the BIOS to format the drives, then install windows, then the graphics drivers etc, but with no image that's a bit difficult!
The monitor works fine with the old PC, so it's not a problem with that. The motherboard has no graphics output on board at all, so it had to use the graphics card from the off.
Any ideas? I should be able to borrow an LCD monitor with DVI input tonight, might that work?
All advice greatfully recieved!
Ben
What I have is;
2Gb RAM
DVD+/- RW
New XP Pro OS
Ben
