I know that some people (usually new people to the forum) may think that I know everything about Unos, or that I think I know everything about Unos, but neither of these thoughts is true
So with that out of the way, I'd like to know what would be the most likely cause of low oil pressure at idle with the 999cc FIRE engine once it's warmed-up after a 15-minute drive at a reasonable pace. And yes, this is the $120 project Uno, I've neglected to update that thread yet, sorry
Symptom is, oil pressure warning light goes out quickly when engine starts, but once engine is warm (properly warm but not over-exerted), warning light comes back on and stays on with engine at 1000RPM or less.
It's really disturbing to see the light coming on (as you can imagine) - I've been using the choke (just the first part, not the enriching-part) to increase the revs so that the light doesn't come on when I move off from traffic lights etc. since we all know that driving with the light on is going to wreck the engine.
I wasn't so worried about this until today (since the engine runs smoothly and quietly, no knocking.) Then I fitted a brand-new oil pressure sender switch and also changed the oil for a third time (the filter was changed the second time and that made no difference), and this time I put in 20W50 (nice and thick) - and neither of these made any difference! So it's a serious problem
What I'd like to know is, what is the typical cause of this on a FIRE?
On the larger FIAT twin-cams, the oil pump is mounted on the end of the crankshaft and has a thick steel plate on the back (inside the crankcase), held on by countersunk screws. Sometimes these screws work loose and the oil pressure leaks out to the sump. Does this apply to the FIRE?
Some other FIATs have a piston-type valve for the oil pump pressure relief. If this were to stick open, would there still be sufficient pressure to put the light out with the engine cold - and does the FIRE have one of these piston-type relief valves that is likely to stick?
I've heard of stories where some engines lose drive to the oil pump, but I think the FIRE oil pump is mounted on the end of the crankshaft, in the housing that has the filter attached - is this correct?
Finally, do you think that the low oil pressure is the symptom of worn bearings rather than the cause? It seems like a chicken-and-egg situation and I'm feeling out of my depth! Do we have to replace all the bearing shells to cure it?
Thanks for any light you can shed, please. I tried a search but didn't find any case of low oil pressure with a FIRE engine. I'm prepared for a flaming if it has been covered before
-Alex
-Alex
