Hi Guys, Yesterday I decided to change the plugs on the 02 1.2 Stilo, as it was well overdue, anyway, I removed the first coil, I was greeted with the sight of it coated in oil!! with oil coating the walls of the coil housing down to the plug, I quickly replced it and checked the second coil, same thing!, so I'm asking where do you think the oil is coming from, is this likely to be a blown gasket, and if so is it a big repair job, amazingly the car still runs fine, and I had no prior indication that anything was wrong!
What do you folks think?
