Has anyone done an oil and oil filter change on there 0.9 twin air and if so can the filter be removed from the top.
Thanks for any info,
Fran
anybody fancy giving a difinative{sp}
answer to the TA's oil requirements ( I've stuck with Selenia)
Read this thread in its entirety. It will likely leave you feeling confused.
It seems Fiat's official oil specification for the TA depends on the date of original manufacture but basically 5W40 ACEA C3 for the earlier cars and 0W30 ACEA C2 for the later ones. Both are fully synthetic oils.
To further add to the confusion, it's been reported that some multifranchise main dealers use whatever they have bought in bulk for servicing petrol cars generally.
If you use whatever is recommended in the handbook that came with the car (which will likely be on a CD), at least you will be covered as far as the manufacturer's warranty is concerned.
and he charged me £40 for the filter and labour, which I thought was pretty fair.
If you peer over the top of the engine and look down from the right-hand side (viewed from the front), you will see the filter housing. It has a rounded top with a hexagonal shape on top. The filter cartridge is inside this housing. It looks like you could undo it with a socket and universal coupling, but I chickened out and gave the job to my local trusted mechanic. I don't know if he removed the air filter housing to improve access. I supplied the oil (Edge 5W 40, £30 for 4 from Costco), and he charged me £40 for the filter and labour, which I thought was pretty fair.
(apparently like a Morris Minor..!!)
cant you just put any filter that fits in it in it jrkitchign? I mean, from what I see a filter is just a metal circle that you screw on = )except that you can buy one for a Morris Minor for under £4.
I predict a huge fall in TA filter element prices once the fleet ages to the point where a significant percentage are being serviced outside the franchised dealer network.
