- Joined
- Feb 28, 2016
- Messages
- 942
- Points
- 256
Check the springs are sat in the holders correctly up against the stops in the arms and you may have to remove and refit the rubber upper mounts so they sit right.
Excellent, thank you, will swap rear springs and see what happens, before we do this. Would this also happen with just the driver on board on that higher side and would that imbalance lock the front left wheel? Thanks.So rhd rides higher, also lifts of the ground first so I suspect passenger rear spring is weaker. Removing rear sprigs and swapping is easier than the front upright.
Will do.Check the springs are sat in the holders correctly up against the stops in the arms and you may have to remove and refit the rubber upper mounts so they sit right.
I just thought that my weight on the higher side would push that side down more making the difference in height negligible regarding the braking issue.?Not certain. A driver can be 20% of the cars weight so it's possible it would make a difference.
Thank you for such an in depth reply. The springs are the originals and the same on both sides. Both cylinders are the same and replaced as a pair. We have swapped wheels over and the issue remains so not the tyres etc.If your car is diving to one side under brakes, you have a brake problem. If there were a weight / steering geometry problem severe enough to make it dive to one side under brakes, it would be obvious all the time the car is moving (and it seems you've covered all the geometry and condition of the steering components already, your idler arm / king pins ' tie rods aren't about to fall off onto the road). Check again that all the self-adjusters are properly functioning; they're a very simple system on these cars and unique in my experience- seems to me that if the system were 100% reliable it would have been adopted elsewhere as it is far less complex than other systems. I'd be thoroughly checking the adjustment mechanism to ensure that the shoes aren't creeping back more on one side than the other. Check the shoe return springs- are they identical both sides? Check the orientation of leading / trailing shoe- drum brakes have a 'self-servo' effect and the orientation of the shoes is important. Check that one wheel cylinder does not have a larger bore than the other due to previous overhauling. As a very much less likely source of the problem, an important part of the brake system is the grip of the tyre bead on the wheel rim. Easy to check by putting a chalk line across the sidewall and the rim and checking it's in the same place after some braking. Again, far less likely than the problem being inside the brake drum.
Thank you they springs are the originals still.Did you replace any of the brake shoe retaining springs? New replacements are known to cause problems due to being slightly different in length.
Thank you, we will refit the hub on the right side as I know that is all new, then take the drum off the "locking" left side to see what's what.I think I'd carefully check the shoes have the linings properly applied, i.e. where the friction material starts, the leading / trailing edges of the shoe. I'd struggle to give an explanation in writing, so look at where the friction material starts & ends on the two brake shoes in this picture. Check that your brakes are set up the same each side with regard to this. The non-lined area of brake shoe at the 1 o'clock position in this image is particularly important, and if it's different left / right it will give different self-servoing effect. Just trying to offer possibilities that you may not have checked.
Here's our locking side, have fitted new shoes whilst in there again.I think I'd carefully check the shoes have the linings properly applied, i.e. where the friction material starts, the leading / trailing edges of the shoe. I'd struggle to give an explanation in writing, so look at where the friction material starts & ends on the two brake shoes in this picture. Check that your brakes are set up the same each side with regard to this. The non-lined area of brake shoe at the 1 o'clock position in this image is particularly important, and if it's different left / right it will give different self-servoing effect. Just trying to offer possibilities that you may not have checked.
Many thanks, how can we tell the difference between a leading and trailing shoe?You bleed brakes starting with the one furthest from the master cylinder by the travel of the fluid, not by geography. Given that my Tony is completely dismantled at present, I'm not 100% sure which that is, but look at where the brake fluid line divides to the rear brakes and start with the one with the longest fluid line, finishing with the shortest fluid line (and honestly it doesn't make that much difference in practice).
With the leading / trailing shoe thing- check that they're the same both sides. You appear to have two 'trailing' shoes in that photo, just make sure you don't have two 'leading' shoes on the other side. Might be yet another red herring but worth a look, people are often unaware that there's a difference so don't pay attention to this when fitting brake shoes.
As it sounds like your problem is perhaps coming from the rear, you now have a list of things to check for back there as well. Good luck.
