OBD code - Evo 1,4
OBD code - Evo 1,4
ted
Sudbury
orange engine block warning light appeared on dash
Plugged in my "Mbuynow® MS300 MaxiScan CAN OBDII" reader to find NO fault code
then "reset fault code" and the lamp was extinguished
So how can you extinguish a fault that doesn`t exist
Had this lamp come up twice now and no code to read, first time it went out on its own
May seem bizarre but both on blistering hot days, when I initially start engine
probably a poor connection issue.. where the joint had opened up with the heat.. could be a bugger to find though.. : - {
look for similar in the GP /EVO / Punto sections as they're all pretty similar under the shiny bits..,
Charlie
