General non starting 1998 ducacto 2.8 maxi.
redjet
Hi all, just thought I would put this on here for reference for others. My 1998 ducacto 2.8 maxi just decided to stop turning over when i turned the ignition key and just made a clicking sound from under the glove box. Low battery or loose terminal I hear you cry, but no. I did a bit of research and apparently there is some kind of module under the glove compartment to do with starting the motor. Anyway it seems that if you disconnect the battery, leave it disconnected for a while(in my case 1 hour), then reconnonect away you go. I nearly bought a new battery but this seems to have solved the problem. hope this info will help others. Dave.:eek:
My 1.9 diesel is doing exactly the same thing, I am going to try that tomorrow but do you or anyone else if this is very common or whether there is a more perminent fix???????
Cheers Jon :confused:
