Technical Light or maxi chassis
growlybear
Derbyshire
Hello All
I'd like to know whether my Hymer Exsis i414 is built on the light or maxi chassis.
What do i need to find this out?
It's a 2015, 3 litre Comfortmatic on 16inch alloys.
Great. I'll measure this when I'm back from holiday.
Be careful!
My Fiat Ducato is light chassis with 130PCD.
Checked and double checked when changing alloys. Supplier was concerned I was mistaken so dry fit even after measuring the bolts.
It
These are from the Hymer Alko vin
1850kg front
2000kg rear
Its the light chassis
The Heavy Chassis is 2100kg front, 2400kg rear
I thought it would be because I've never seen a mass market motorhome converter using a heavier chassis than they have to
Even Hymers have to economise on tare weight and cost
If a light chassis the wheel will be 118PCD and if heavy chassis 130PCD.
You must be reading from an old book
Thats how it was for many years, but they are also using 130PCD on the light chassis now.
Best guide is the axle weights shown on the rating plate on the slam panel - (the crossmember the front of the bonnet slams on to)
Heavy is 2100/2400
Heavy is 2100/2400
I was answering the original question regarding 2015 models
