Retro Pedro
- Joined
- Apr 24, 2011
- Messages
- 233
- Points
- 56
Plea for advice and help please
I've got a 1.9JTD 8 valve 105 Doblo diesel that doesn't want to start. Initially my suspicions are fuel starvation.
A couple of weeks back I was starting to get problems with it cutting out after start up. Car would start and run OK until I came to a junction and it would just cut out with a flashing glow plug light evident. Car would restart no problems straight away and after a few repeat situations it would warm up and run normally.
The car as been jacked up at the front and not started for approx. 10 days whilst I was replacing both lower front wishbones and engine mount. Got it all back together and front wheels back on and back down on the ground. Now it won't start. The battery was struggling to turn it over so I whipped it off and gave the battery a recharge. Turns the engine over fine now but still it won't start.
My first thought was that maybe the fuel ran back and created an airlock. Thought OK, should I be buying myself a 12 volt small priming pump and reprime the fuel system. Had a hunt on this forum and found a thread in the Stilo section and it seems the 1.9JTD is self priming. Read that the procedure is to switch the ignition on for 10 seconds without trying to start the engine. Repeat this 4 to 5 times and the fuel system should prime itself. Tried this and it made no difference, still not starting. Next, in turn, I disconnected the fuel pipes from the main fuel filter to try and see if fuel was being pushed up by the tank lift pump. With the use of a glass jar, I turned the engine to try and judge how much fuel was being delivered to the filter. I would describe the fuel flow rate as a dribble rather than a flow so I'm wondering if that is correct. I then reconnected the feed line and unclipped the line that feeds the main fuel pump. Again, only a dribble comes through. That sort of told be the filter is allowing diesel through but I'm not convinced about the non existant flow rate.
Had I had a convincing flow rate, I was going to slightly crack off one of the fuel feed pipes from the pump to the injector to see if fuel was getting drawn in and pressurised by the main pressure pump. But without a decent flow rate reaching the pressure pump, thought this might be a no no. Had I got to the stage of proving I had good fuel pressure reaching the injectors I would have thought the problem would have been electrical/sensor related with the ECU not allowing the injectors to pulse.
At the moment I'm thinking that maybe I should be finding the tank lift pump and see if there's any blockages or dirt clogging the filter. Then maybe check the fuel pipes to see if there is anything suspicious with kinks etc. causing any problems. That said, I can't see any evidence of fuel leaking under the car.
Going back to the main pressure pump, I do need to check the cam belt but in all honesty, I don't thing anything will be wrong with the belt because it was only recently replaced.
Any advice or pointers would be very much appreciated.
