Technical No idea about engines
Evilpaperclip
Hastings
So I have no idea about engines, I can't picture what you guys are talking about and I can't fix my car (if ever I need to) if I dont know about engines.
I was jsut wondering how you guys got your knowledge. I was thinking of going to a scrappy's and asking whether I can take a fiat apart, that'd probably be best for me cos I dont want to kill my car just yet.
But I don't have loads of time to get to a scrappy's and will he charge me to rip it apart and then (hopefully) put it together again.
Or maybe I should buy a heap of junk and park it outside my house and rip that apart. Might be cheaper and I can always refer back to it cos its outside.
Im open to any other ideas, i will also be reading through the guides and FAQs trying to get as much clear as I can.
As it happens Ive gotta fix the tappets on my car, but the Haynes for the cinq isnt as clear as I'd like it to be, not enough pictures either.
So yea any ideas are welcome :)
Evilpaperclip
Events Team
Join the team
Psst! Are you free August the 2nd??
Then come and join us at FIATs and Friends.
Held at the British Motor Museum, there will be loads to see and do so there's no excuse not to be there 😜
Sign up using the link above to register yourself for our stand - everyone is welcome!
just dive in. i'd never worked on a car before until my cinq first blew its HG - garages quoted me £300 to fix, so i bought a tool kit (£100) and a haynes (£15ish) and got cracking with it.
As i said in PM. Dont think a scrappy would be too impressed unless you buy what you take off. lol.
Just buy the tools as you need them if money is a bit tight. Am sure if you cant find what tools are needed from the searches someone will tell you very quickly.
Most people on this forum will probably tell you the same to just read read and read the haynes, etc and then play and that is the best advice. Most of us will know where in the haynes each section is, which is really quite sad, but illustrates how useful it is. Pics are very carp but you get to know your engine from every angle. :rolleyes:
Enjoy playing with your car, whats the worst that can happen. New engine is 100 quid. :)
The car itslef cost 600 lol XD Lovely car tho, just wish it had some more oomph, but Ill cross that road when I get to it
I started learning along time ago with my first car. Haynes manuals existed then, and i bought tools as i needed them.
I got a job as a mechanic on the strength of my self learnt knowledge.
Haynes makes a lot more sense when you've got the bits in front of you.
Cheers
SPD
well according to Haynes I gotta lift the car to get it to TDC and cars tend to be quite heavy :( Besides I have allen keys :D How important is a torque wrench?
You sir are a genius! Damn and Ive been waiting for ages for these damn stands...
Would I need a torque wrench when trying to fix the tappets? Not for the tappets themselves but for any part that needs to come off to gain access.
Otherwise I can probably fix it this weekend :D
Thanks!
No need for a torque wrench, although be careful that you don't overtighten and bolts.
The rocker cover is allen bolts, after you've removed the TB. There is no need to remove the fuel pipes from the TB, remove the throttle cable and the TB will swing out the way with the pipes still attached.
Doing this whole job use spanners rather than a socket set, less likely to strip bolts by overtightening.
Cheers
SPD
Ahh cool and with the tappets, Haynes mentions a FIAT adapter tool or something to pre load them. Is it crucial or can it be done with spanners?
And will I need a feeler gauge, bearing in mind they, should be, hydraulic tappets :p Dad said I might need one anyway
Im a poor student currently, only JUST managed to get my current cinq :p I wonder if my friend has his totalled sei... thatd be quite good.
Yea it is, sometimes it doesnt happen when cold ad so I assume theres enough oil in the tappets
OK, In my humble opinion, don't take the rocker cover off. A tappet is a bit sticky, you are unlikely to find it just like that and then you are going to have to replace it.
Its preload will be fine, it stops ticking when it unsticks.
Save up your pennies and treat the car to another oil and filter change in 3000 miles.
Make sure you use 10w40 or 15w40.
Maintain your car in the best running order. Check the tyre pressures and all the lights and levels every week. mke sure the coolant is not only up to level, but bled and of the correct quality.
If you want to get the tool box out, check the gearbox oil level.
Do a search on this site for details. That will ber fa more beneficial thn trying to find a sometimes sticky tappet.
Cheers
SPD
Right ok, I was planning on changing pretty much everything as im not so sure that the previous owners took amazing care of it, so i was going to change the oil and filter, change the coolant cos it looks a bit nasty in there, change the brake fluid, pretty much just follow the Haynes on the weekly inspectiosn and do some of the yearly ones now.
