Technical No heat/fan/cooling
PaddyJ
I've recently bought a 57 (2007) plate Bravo (with FSH) off a family member with a known fault of no heating on the passenger side - no other issues.
However on Sunday I want to switch the A/C on & nothing happened - no fan, auto mode not selectable & the aircon button did nothing.
I've had a good look about the internet & removed the glovebox but what I see behind there bears no resemblance to any thread that I've read - I'm looking at the interior fuse box (with a big immoveable cable zip tied across a good half of the 30 or so fuses) & pretty much nothing else. I was hoping to check out the resistor to see if that was done-for. With the ignition on I hear at least one of the actuators - the source of the cold passenger no doubt.
Can anyone guide me as to where the resistor can be found on a 2007 RHD Bravo, & where the actuators are.
Cheers Paddy
Update:
I checked all the fuses I spoke about earlier - they're all good (as are the ones in the engine bay).
Had a really good look all over the passenger side & there's nothing to be found.
I then stumbled across the eLearn tool which describes where it can be found but when I looked it's not there :bang:. See attachments.
Does anyone know where is this mythical heater resistor is (on a RHD Bravo II with climate control) ?? Cheers
Im not aure on the bravo but on the punto it's a couple inches from the right of the motor
Cheers my friend.:) I'll let you know when I find it; which, if you're right, will be shortly after I find the motor.
Hello,
The heat resistor is located at the lower front of the fan motor.
Please check the relays in the engine bay.
I had the same problem and the solution was the relay.
