Ducatofunzi
Hi all,
already put lots of effort to find the correct steering column unit for RETROFIT, WITH speed limiter AND cruise control - however failed with asking FIAT PROFESSIONAL dealers, suppliers (MEAT & DORIA) ,"experts" and other forums.
Status as follows:
HELP HIGHLY APPRECIATED!
- Ducato 250-SA Maxi 180 3.0 Facelift 09/2014
BR
Status as follows:
- have OBD programmed the speed limiter & cruise control - both are correctly showing up at the LED panel, as well Km/h programming is possible at the speed limiter
- however - there is no chance to realy activate the speed limiter when driving
- cruise control is working only "half" - i. e. in 2nd, 3rd, 5th gear it can be operated excellent - in 4th gear it is hard to switch in (sometimes it works some not...), 6th gear does not work at all
- had installed (plugged in to existing steering column switches) an original cruise & speed limiter - found lately that it was from a 2.0 Peugeot Boxer, 5-gear, low hp
- as my car is the 09/2015, 250, 3.0 MJ 177hp with 6. gear - I ASSUME, IT IS JUST THE WRONG UNIT INSTALLED ...
- Frame-No: ZFA250 000 0*****
- Version: 250DPMFC HY1
- Engine: F1CE3481E
- Gearbox: M40- V, 6-gear
BR
