Truckcab79
- Joined
- Feb 8, 2021
- Messages
- 12
- Points
- 3
Hi All
I have a Fiat Doblo cargo Professional 2015. Bought it last September and really happy with it (ignoring the new turbo it cost me)
All good until this morning when I caught out on a hill that in any other vehicle I’d have probably got away with by switching off the ASR. ASR activated and of course I lost anything approaching traction and got stuck sideways across the road.
I have a light on the dash (car with wiggly lines behind it), and between the seat an ASR off warning light. However I appear to have absolutely no way of turning it off when needed. I’ve never had a vehicle where you couldn’t switch it off and have always needed to at some point
Googled it and searched on here and can’t find any mention of anyone having the same issue. Checked the manual and it says that there should be a switch on the dash. In the location stated, all I have is a button to position the headlight angle down. Even pressed it to makes sure someone hadn’t swapped it out with a ‘spare’ switch and lo and behold it just adjust the headlights.
Can it be that I can’t turn it off?
Switch between the seats looks like it has a blanking plate above it as if maybe that’s were it should be situated. If that’s the case is there a way to swap the switch and retro-fit. Is the wiring there anyway even if switching it off is an optional extra?! Even the manual tells you it will be needed to be switched off in snowy conditions
Thanks in advance.
Thanks in advance.
